Sweep with two "points"
I'm new to solid works and I'm trying to creat a sweep with a profile (circle), a path (spline) a a guide curve (spline).
The two spline intesect with it othe making two points, so I can't create the circle at the end of the spline.
I tried to create the circle around the midle of the curve but the sweep only take one direction.
What I need to do to have the sweep go both ways?
RE: Sweep with two "points"
You could just sweep one direction then the other.  Otherwise you need to think about lofts.
Dan
www.eltronresearch.com
Dan's Blog
but how do you chose the direction?
there is no "arrow" or menu to make this selection...
Create a separate sketch for each swept half.
You can derive the sketch too, so it always updates correctly in both halves of the sweep...
I made two separated sketchs and it worked.
@gwubs: How do you derive a sketch?
Select a face for the sketch ten CTRL select an existing sketch.  Then go to Insert/Derived Sketch.  Check the Help for more info.
Dan
Dan's Blog
You can use same Profile or Spline curves for both directions.
Derived sketches cannot be edited other than to select a different sketch plane and orientation for sketch. To help place the Derived sketch it helps to put additional centerlines to use to place derived sketch with relations.
You can also use the Selection Manager to change the extents of the selected path or guide. After selecting the Reference sketch you'll see Grey dots at endpoints of curve that can be dragged back to set the direction as shown in attached pictures.
A better way to split the Spline curve into two directions would be to use convert entities in a new sketch and then the Split icon in sketch to divide the curve in to two portions which can be selected using the select group option of Selection Manager.
Michael
