3 Point Center Rectangle Tool doesn't center.
Can someone please help me with this? I've had this happen for a long time and I can't for the life of me figure out why the 3 point center rectangle tool just doesn't work like it should.
I make the outline:
http://www.victorlinphoto.com/downloads/sld1.jpg
But then it just turns to this:
http://www.victorlinphoto.com/downloads/sld2.jpg
The entire drawing just pops off center for no apparent reason...
I make the outline:
RE: 3 Point Center Rectangle Tool doesn't center.
-handleman, CSWP (The new, easy test)
2) I'm currently using SW09-SP3 and SW2010 Beta and it's happening in both. It only appears to happen when the centre of the rectangle is in line with the centre of the bar.
You should create a video (Rx or screen capture) and submit it to your VAR.
