ansys WB 12: unable to start the mechanical editor. HELP ME!
I'm trying to use the new version ansys workbench 12 but, after installation of the program and the license, I make my geometry in DesignModeler and when I try to enter in Mesh Ansys say: error:UNABLE TO START THE MECHANICAL EDITOR and appear a fast window that say: AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:\DOCUME~1\carlo\IMPOST~1\Temp\AnsysWBDumpFile.dmp
But I don't find this file and neither the folder IMPOST
I don't know where is the problem, please help me
Carlo
Carlo
RE: ansys WB 12: unable to start the mechanical editor. HELP ME!
by the way, "Impost-1" is the abbreviation (using 8 characters) of, presumibly, "Impostazioni Locali"
Did you manage to solve this problem? I have the exact same problem...
Christian
I also encountered the same problem and just like Christian, I was wondering if you got it solved.........
Thanx
we solved the problem (or to be more precise, ANSYS Support Team sorted me out).
In my case, it turned out, the error occured due to overwriting of some files after my operating system installed a couple of updates. The updates triggered the script error that hindered mechanical in the workbench to open.
How we solved it? We got rid of the old Workbench 12.0 profile and allowed it to reconstruct a new one. How:
1. renamed the '.ansys' directory in %temp% to 'ansys_old'
2. renamed the 'ansys12.0' and 'v120' directories in %appdata% directory to 'ansys12.0_old' and 'v120_old' resp.
3. restarted simulation in workbench
4. carry on simulations like nothing happened
Have a lot of fun!
And appears such error to, what i may do to solve it?
Anyone can help me.
I didn't find such dirs like ansys12.0 or v120
But i have found out what my problem was. My computer is connected to a network with all quint of security etc etc... The virus scanner was the problem! I De-installed ANSYS and disabled the virus scanner and installed it again. No problems anymore!
So StrMisha maybe you can give it a try!
Cheers!
Christian
Thank you a lot!
After deleting anti-virus and reinstalling Ansys.
Christian
I have the same issue (can not start the mesher in Ansys 12) and get the same error message.
I tried all what you mentionned above, but it does not fix the issue.
Does anybody have other ideas ?
How can I know if the installation happened fine or not ?
Any help more than welcome !!!!!
Zeitoun
Can I recommend you contact your local support team? This problem can be related to graphics drivers, but also can be produced due to other problems with the installation, such as pre-requisites have not been installed.
