Rebuild Error.. (Simple Question)
If you take a look at the jpeg, you can see what Im trying to do. Im trying to use the "Revolved Boss/Base" feature command to create this part. But I keep getting a Rebuild Error that says "Resulting feature is too large to fit in the modeler limits. This operation will fail."
Any suggestions will be much appreciated.
RE: Rebuild Error.. (Simple Question)
Joe Hasik, CSWP/SMTL
SW 09 x64, SP 3.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
Dan
www.eltronresearch.com
Dan's Blog
And the part has an overall width of just 3".
Dan
Dan's Blog
It could be that the Geometry isn't being created as it's outside the model bounds. I created a similar sketch but off in space and once it went outside the max for geometry based on origin the feature won't create. Select any vertex in your sketch and check the x,y,z location values displayed in status bar at the bottom of the screen.
From your sketch and the part you're making I'm assuming you're using the base line as revolution line and then shelling out the Solid Feature. 2008 SolidWorks and later can use centerlines from other sketches or any Axis feature parallel to sketch for a axis of revolution and only needs to be placed in sketch to create Diameter dimensions.
Michael
Artem Taturevich, CSWP
Software and Design Engineer
AMCBridge LLC
www.amcbridge.com
