Kinematic Coupling applied to a hollow cylinder - will not converge
Here is what I have:
I modeled a hollow cylinder and fixed one of the bases. I created a Ref Point on the longitudinal axis of the cylinder just outside the opposite base. I then applied a kinematic coupling to this base/RP combo and under constraints checked all DOF. Unlike the BC's, this should allow the model to move in any direction. I then applied a moment to this Ref Point about the longitudinal axis.
My material is Hyperelastic and I am using a Tet Mesh. I have already adjusted the step increments to allow the processor more time and increments to converge.
If the moment is small enough the analysis will converge however, I am looking for the cylinder to actually deform and twist/buckle as a rubber hose would if you were to apply the same actions as described above. When the moment is large the analysis will just abort even with the adjusted step increment.
Why won't this happen with the described method and conditions that I am using? Is it the mesh or material maybe? Any help is greatly appreciated.
RE: Kinematic Coupling applied to a hollow cylinder - will not converge
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Martin Stokes CEng MIMechE
If it's a simple cylinder, why use tets? You could easily use bricks or even shell elements if the diameter/thickness ratio is sensible...?
