Power Transformers MV/HV
Hello.
This is a question for Transformers manufacturer. It is possible to design a power transfomer elevator for a voltage of 11 / 400 kV and a power of 60 MVA or having 11kV at primary and for this power the secondary has the limit of 220 kV?.
Any data from IEC Std. related to typical voltage ratio MV / HV and related power for these voltages??.
Thank you in advance for your answer.
Best Regards
Best Regards
RE: Power Transformers MV/HV
I agree that you should be able to get anything you want, certainly 60 MVA at 220 kV is feasible. Check with the transformer manufacturer.
Bill
"Why not the best?"
Jimmy Carter
