Demag/Siemens Centrifugal Cup-seals
Has anyone got some tips for fitting the Spring-held PTFE cup-seals?
We heat them, in hot water to 100degC and pray.  Previously we have used hot oil at 120degC and in a big oven to 180degC, at 180degC they didn't shrink back.
Any feedback would be great.
AD90
RE: Demag/Siemens Centrifugal Cup-seals
What we used to do years ago with PTFE seals is do exactly that heat the oring up with hot water but the trick is to pre-form the ring.  This meant that we had to work the ring on the shaft or had a dummy shaft and slid the ring up and down the shaft.  We had a spring behind the ring and when the spring was able to push the ring with its own spring force, it meant that the ring was formed and ready for use.
I hope this makes some sense.  It worked for us fortunately we rarely use PTFE and it did cause problems on site.
good luck
Thanks Flexibox, they are a royal PITA!  And the logic for using them in this aplication is flawed.  The Compressor end-cover seals are static therefore a bit of explosive decompression will not cause hang up problems.  I can see why they would be used in a shaft seal arrangement that has to cope with End-float.
AD90
