Flare Header
Flare Header
I am trying to estimate vacuum generated in flare due to thermal contraction in flare header due to temperature drop during global scenarios.
How should I estimate rate of condensation?
RE: Flare Header
1.) Use the ideal gas law based on volume of Flare header
2.) Any liquid seal at the Flare drum will operate in reverse to break vacuum (although this may inject air into the flare header.
This is the reason most Flare systems have positive gas injection (fuel gas) into the header.
RE: Flare Header
Onwards,
Matt
