Flex an Assembly in SW2009
I have some nested tubes in an assembly. (Picture a coaxial cable.)
I'm looking for a way to use the Flex feature efficiently so they will bend as a group.
Is there a better way than defining a Flex feature in each of the components?
What would you recommend?
Thanks!
Thanks!
RE: Flex an Assembly in SW2009
Could you use the Sweep function in the creation of the tubes instead of the Flex afterwards?
File
Save as
Save as type --> Part (*.prt, *.sldprt) --> All Components
File Name
Save
