PVC pipe support span
Does anyone know what the support span of PVC pipe, say, 4" pipe, schedule 40 without pressure (just for conduit only)? Where could I find the general description regarding this issue?
Thanks.
Robin
Thanks.
Robin
RE: PVC pipe support span
To get the best answer, ask the vendor of the pipe you are using, or the vendor of similar pipe....
Support span does depend on the fluid in the pipe as well as the temperature. The numbers for a 4" NPS pipe would be from about 9 feet to about 16 feet (my experience only)
Estimating a job ???...... Use 10 foot spans
MJC
In my experience, the support span for 4" pipe is normally
4 to 5m.
This is PVC. so, better we have to ask pipe vendor.
thanks,
uthaya
