Friction Coefficient
Hi, I am looking forward to find out the value of the static friction coefficient of the stainless steel 17-4 PH H1150 on the stainless steel 1.4034, considering that the contact face is dry.
I do have some information precising a static coefficient of 0.2 for a dry 'steel on steel' contact area, do anybody can validate this value?
RE: Friction Coefficient
This table might help, it allows you to compare two materials. I dont think you will be able to get an exact coefficient for the specific materials that you have mentioned other than by testing the two materials.
http
Based on the above, The 0.2 that you refer to would indicate a lubricated steel surface.
