corrosion - chemical injection
Hi.
I am looking after offshore topside equipment (oil/gas).
I am carrying out RBI. on Chemical injection.
ie.
Chemical injection into Stainless tank.(316).
Material Data Sheets suggests that is no problem here.
Is there anything information to the contrary.
regards
ie.
regards
RE: corrosion - chemical injection
Don't know because you don't state what you are injecting into the tank.
To answer your question what is the chemical itself, temperature and concentration of the chemical you are injecting into the 316 ss tank?
