Flow rate for Plate Heat Exchanger
Assuming I have a pump which supplied water to PHE (cold-side) at 50m3/hr.
what happen if the supply of water is decrease since i'm want to tap that line for other services?
RE: Flow rate for Plate Heat Exchanger
Best regards
Morten
is there any way to overcome this problem without changing the pump?
I'm thinking to add more plate cooler as to increase the effeciency of heat tranfer rate.
any advise?
Best regards
Morten
You could, however check with your Hx vendor about two passing your cold water side (or both).
rmw
