Float for transformer oil
We are currently building an oil containment pit, with sump, for some power transformers.  I need to find a float that will not break down in mineral (transformer)oil.  The float we used in previous designs appears to be inadequate as the cable tends to break down in the mineral oil.  Does anybody know of any manufacturers of these?  (Canada or United States).
Thanks in advance.
RE: Float for transformer oil
Depending on importance of the process/knowing level, you might also consider capacitive, plastic-encased probe-type sensors that will sense oil and oil+rainwater.
Years ago we manufactured transformers and used Qualitrol gauges. Try www.qualitrolcorp.com/liqlevl
I don't know about this, but maybe a diesel fuel sensor would work.
