Water Box Gasket Material Properties
Any one familar with gasket material selection out there?
I am specifing the material of a water box gasket with max. pressure 150 psi and max temp. 130 F. Looking for advise on the following properties: hardness per ASTM2240, Compression set 25% compressor per D395, creep relaxation.
Thanks in advance!
RE: Water Box Gasket Material Properties
wzal, have you condsidered contacting Flexitallic, Garlock, Clipper, etc, etc?
Mike
