Galvanic Corrosion of Brass Tubesheet
We have a brass exchanger tubesheet with Monel tubes. The brass tubesheet is failing in a manner that I haven't seen before. The brass is coming off in a "stringy" type fashion instead of pitting or cracking. Is this common in brass ? Is this typical of brass/monel galvanic corrosion ?
RE: Galvanic Corrosion of Brass Tubesheet
