I need 3.6 not 3.5999
Hi all,
I am making a code using fortran77.
I input 3.6. Strangely when I call the value, it gives me 3.5999.
Do you know how to fix this problem?
Please help me.
Thank you.
RE: I need 3.6 not 3.5999
No, it is not. I am working on a code for my research.
I'm just biginner of Fortran.
Thank you.
I need to use the value to calculate another value. I defined the value of 3.6 to "CA". The problem is that "CA" is called as 3.59999. It gave me wrong answer because the calculation is conducted with 3.5999.
I think you have a more serious problem of why you can get a "right" answer at 3.59999, but a "wrong" answer at 3.5999.  The uncertainty in any real world scenario will swamp out this trivial precision error.
You need to explain more about your problem.
TTFN
Sorry about bothering you. I mean I want to use 3.6. But, during the computation, 3.5999 is used instead of 3.6 even though I input 3.6 as an value.
The issue is that you cannot get exactly 3.6, because it's not a binary number.  Have you checked the numerical precision of your variables?  Do you really expect people to know what you did in your program without a listing?
TTFN
I appreciate your explanation.
I understand what you mean.
Frankly, I don't know how to check the numerical precision.
Could you let me know how to check?
Thank you.
Yes, I'm reading the manual. It is quite difficult to me. It is my first coding in my life.
I'm learning and, at the same time, coding the program.
It is a long time since I worked in FORTRAN - it was still called FORTRAN IV when I learnt it!  Did you declare the TYPE for your variable CA?  Try declaring it as DOUBLE PRECISION or whatever the equivalent is in FORTRAN 77. If you have enough 9's after the 5 the value becomes indistinguishable from 3.6
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
Another trick is to multiply by 36 and then divide the answer by 10.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Sorry Cajun, but that is nonsense!
If you work with integer variables and divide 360 by 10, yes you would get 36, no problem.
But divide 36 by 10, with integer variables would give 3, with real variables (whether single or double precision) you would get something like 3.599999 or 3.600001, but never precisiely 3.6
==> Sorry Cajun, but that is nonsense!
Not, it is a quite valid technique to substantially reduce floating point roundoff error.
Good Luck
Cajun,
Real variables in fortran are stored as a mantissa and an exponent.
A single precision real variable is 4 bytes = 32 bits, of those 32 bits, 24 store the mantissa and 8 store the exponent.
Thus changing the value of the exponent will not change the accuracy of computation in fortran!
In fact by including the additional computation of dividing by 10 you are introducing more round off errors not reducing them!
Believe what you will, but I know the actual code being generated by many, not all, but many FORTRAN compilers.
Good Luck
So its not stored as a mantissa and an exponent?
IRstuff,
The code is quite long. How can I post it?
see:
Step 3
  at bottom of the dialog box.
You need to figure out what to extract.  How do you expect anyone to debug your code, sight unseen?
Why is your manager giving you such a complicated task?
TTFN
Integer BURB
DOUBLE PRECISION BUR
BUR=3.6
BURB=1.0+(BUR+140.0)/0.2
In this code, 'BURB' is calculated as 718.
I want 719.
I want to get right value for 'BURB'. I understand you about the binary numbers.
I want to use 'Burb' as a indicator of interation. That's it.
Welcome to the delights of mixed-mode arithmetic.  It causes tears (and blood, and sweat) in every language I have ever worked in.
I believe Denial is correct. If you are leaving the REAL to INTEGER conversion up to the compiler then you are asking for trouble, in any language or compiler. Rather do it under your own control. See the post by johnhors in thread545-95464: Rounding REAL numbers.
Do something like
Integer BURB
DOUBLE PRECISION BUR, BURA
BUR=3.6
BURA=1.0+(BUR+140.0)/0.2
BURB=INT(BURA+0.5)
Katmar Software
It's simpler than that.  BUR can simply be defined as 18 to start with and avoid both the decimal fraction and the division by 0.2.  Likewise, the constant 140/0.2 should simply be written as 140*5 or just 700.  At that point, one wonders what the exact purpose of the additional 1 is.
Just an iota of research would have made it plainly obvious that the coding is at fault.  However, you need to review what the purpose of the equation as written is, since it's both cumbersome and questionable in intent.
TTFN
The number is being rounded down.  Use nint to get the nearest integer.
CODE
BURB=NINT(1.0+(BUR+140.0)/0.2)
If you are getting timing problems (say you need to compute this a few million times, use
CODE
BURB=NINT(1.0+(BUR+140.0)*5.0)
IRstuff - I agree with your comments in your last post. I would also question the OP's statement "I am making a code using fortran77." as fortran77 is now obsolete, I use silverfrost ftn95, they no longer support their ftn77 product, in the gnu community f77 is also no longer supported having moved on to g95 or gfortran.
Hello:
Just try this for Format F3.1, this should take care of it
