Fillet bead uniformity
Take a look at the attached image. Is there a way to make the fillet bead uniform around the intersection? Any idea why SW chose to create the fillet bead like it did? Thanks.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Fillet bead uniformity
I've never tried, but I imagine you would have to dress the edges of the hole and pipe end with varying bevels in order to create consistent joint surfaces condition.
And good luck with that.
