NX5 Keyboard Shoutcuts / Hot Keys
julianhood (Automotive)
This is in response to a previous closed post which someone was looking for a printable hotkey / keyboard shortcut list.
Attached is one I generated based on a base installation of NX5. Hope it may help someone...
RE: NX5 Keyboard Shoutcuts / Hot Keys
better to look at you workstation Nx-> information -> custom menue bar -> accelerators.
'Measure Angle...'
...all you have to do, while the pull-down menu is still being displayed, is to hit the 'A' key and the 'Measure Angle' function will be activated.
As for adding multiple Sketch constraints in one operation, just select the 'Constraints' icon and then while holding down the 'Ctrl' key, select the curve(s) which you wish to apply multiple constraints to. The list of possible constraints will remain displayed until you press MB2 accepting the selected constraints. Note that in reality, separate constraint operations will be performed which you will notice if you attempt to Undo this 'multiple constraint' operation.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
For example I use h for hide.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Can Enybody tell me, in which file save NX the hotkeys?
Thank you very much for your reply!
Róbert Boros
Mechanical Engineer
Injection Mold Designer
Hungary
www.bausch.hu
C:\Documents and Settings\<user name>\Local Settings\Application Data\Unigraphics Solutions\NX6
If you have multiple versions of NX installed there will be one folder for each version (I've shown the NX6 version in my example above) which contains all of the settings such as customer default files, Roles, menu/toolbar settings, history file, etc.
John R. Baker, P.E.
Industry Sector
Cypress, CA
