insert and orient axis relative to x,y,z
Is it possible to insert and orient an axis or user coordinte system with angles relative to the initial x,y,z
axis? I have a part machining axis that is set relative to X,Y,Z. But I cannot figure out how to specify these relations.
RE: insert and orient axis relative to x,y,z
Try the Coordinate System Icon found on your Reference toolbar. I think this will get you what you need.
BBJT CSWP
Next, use Insert/Reference Geometry/Coordinate System: pick the command, select your new origin, then select two surfaces, existing or new planes that you want to be normal (square) to two of your new axes. The third axis will be defined implicitly as normal to the two you define.
Jon
jgbena@yahoo.com
