Need a Photoelectric Sensor
Hi all!  We have an application requiring the use of a U-shaped (also known as slot or fork style) photoelectric sensor.  The application requires that the size of the sensor be around 16mm X 14mm X 6mm.  Ideally I would like to try out sensors from several different manufacturers but I am having a lot of trouble finding any that are this small.  Anyone know where I could find some?
