Selecting all Entities
I was trying to select all entities in a SolidWorks drawing through SolidWorks API.
The drawing has been created from a dxf.
I searched for a method for window selection, I think its not avaialble.
Can someone has steps to do such selection.
Vinay
Vinay
RE: Selecting all Entities
Please refer the following macro:
Dim swApp As SldWorks.SldWorks
Dim swDraw As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swSketch As SldWorks.Sketch
Dim vSegs As Variant
Dim swSkSeg As SldWorks.SketchSegment
Dim i As Integer
Sub main()
Set swApp = Application.SldWorks
Set swDraw = swApp.ActiveDoc
Set swView = swDraw.GetFirstView
Set swSketch = swView.GetSketch
vSegs = swSketch.GetSketchSegments
For i = 0 To UBound(vSegs)
Set swSkSeg = vSegs(i)
swSkSeg.Select4 True, Nothing
Next
End Sub
BTW. You can also perform a window selection using IMouse interface. You can simulate mouse clicks from one corner to another opposite one so it will looks like 'real' selection
Artem Taturevich
CSWP
Artem Taturevich
CSWP
Your VB code will help me.
Actually I wanted to move all entities to one layer.
I selected all entities but now I am facing difficulty to find a method to move all entities to one layer.
I try to make the desired layer active after selecting, but its not working.
Artem Taturevich
CSWP
