Measuring strain rate
I'm looking to measure the strain rate on the mast of a drilling rig while in service. What sort of experimental setup should I look into?
RE: Measuring strain rate
Fe
If this is a one time deal you are probably better off hiring someone. It is quite easy to waste a lot of time/money trying to install gages the first time. And if you don't know what you are doing it is easy to get bad data. One firm I have used several times is All Test out of Minnesota (alltest.com).
ISZ
Let me ask you this - is there a device or method that is capable of measuring strain RATE directly?
http://w
Fe
