Saving Inventor file as dwg
I have a client who needs one of my Inventor Assembly drawings so he can work with it in a 3d program. He needs a .dwg file.
Is there a way to save an Inventor Assembly File (.iam) as a .dwg?
There is nothing in Inventor's "Save Copy As", or "Export".
This client needs to work with a 3d autocad file of this assembly.
I am currently using Inventor 2010.
ANY help would be appreciated.
RE: Saving Inventor file as dwg
In Inventor savecopyas your model to a .sat file
Autocad can easily import .sat files.
If I can't make a .dwg file from the .iam, I'll have to see if his program can use a different file extension.
His first preference was a .dwg extension.
iges/stp/stl (I bet it can import at least one of those)
Or better yet what program is he actually using.
I will have to ask what other format he can use.
He originally said his first choice was .dwg.
But I'd think he could use other formats that might be better/easier for you to provide him with..
I am going to send it to customer and see if that's okay.
I was going to do the same for a Inventor Presentation drawing, but I see you cannot export to a .sat from a presentation drawing. I guess he won't get an exploded view. If you know of a way for that, please let me know
Thanks again.
In your assembly or part go to Applications (2009) or Environments (2010) and select AEC Exchange. Then select the Save as DWG solids command.
For the Presentation file, just create an animation yourself and render it to an AVI or WMV for him.
Although if he is using the DWG solids he should be able to pull things apart himself.
Save your assembly with a different name, say Exploded.
Then move your parts apart or with constraint offsets.
Applications (or Environments in 2010) AEC Exchange>Save as DWG Solids.
Make sure you know what version of DWG they need. You might need to open in AutoCAD or DWG True View and set to earlier release of AutoCAD.
How is that any different than the first response to this thread?
