continuous beam
continuous beam
Can someone guide me to moment equations for multiple span continuous beams? Specifically, I need to design a 5-span continuous beam with point loads applied at various locations. Spans are 24'-2"/25'/25'/25'/24'-2".
Thanks.
Thanks.
RE: continuous beam
I do not know of a handbook showing 5 span continuous beams, but maybe someone else has run across one.
If this is concrete, the ACI manual has some general equations for multiple span design, but nothing specific. They are also for uniform loads. What type of loading do you have on the beams? All uniform?
You also need to consider skip loading in multiple span situations. If this is confusing to you, you really need to engage the help of a structural engineer.
Mike McCann
MMC Engineering
RE: continuous beam
IV
RE: continuous beam
RE: continuous beam
RE: continuous beam
RE: continuous beam
Alex's corner is amazing. Thanks for the link.
rb1957,
No, you don't have to be a member.
BA
RE: continuous beam
RE: continuous beam
Be careful of partial loading, this can cause higher moments than if all spans were fully loaded.
RE: continuous beam
BA
