Curve Mesh glitch
Curve Mesh glitch
Curve Mesh glitch
i encountered a problem when trying to apply a through curve mesh  at a edge of a cut off solid body.
I used one of the edges of the 45°cut off cylinder as a cross section when defining the mesh.
The primary strings ended each at the edges of the cylinder (see attached scrs).
The mesh was successfully created and afterwards i carried out an extrude of the mesh surface until extended (bottom of the cylinder) and using one of the cylinder edges as vector.
But then when trying to "combine" bodies a get a error like  "do not form a complete intersection" so its showing up some  "gaps" between the mesh surface and the cut off cylinder. But well that cant be true since i used the edge as reference for the mesh surface - tolerances are 0.001mm.
I finally managed to do a "workaround" by enlarging the mesh surface a little bit "into"  the cylinder like 2/100 mm.
But thats not the way its meant to be ? so why does that issue appear and how to avoid it?
Thx in advance
RE: Curve Mesh glitch
It looks like just a horrible thing to want to try and do there are probably better ways but I couldn't propose much without seeing some geometry in order to better understand what you're trying to achieve. Just looking at you're image I'm torn between suggesting that a completely different construction would be preferable, and questioning the quality of the defining curves as relates to continuity and trying to avoid building into sharp corners.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
