Re using Brick and Concrete
Can anybody offer some guidance on whether brickwork and concrete (from an existing building on site) can be re-used in all or some of the following. General backfill to basement retaining walls, to a driveway and to a car parking area. The project involves the demolition of an existing building and the construction of a new detached property with basement.
If so, crushing, mixing?, placing compacting etc specifications will be needed I presume. Can anybody recommend where I can go for these. I'm in the UK.
RE: Re using Brick and Concrete
I suggest googling for gravel/hardcore suppliers local to your site and discussing with them.
Recycled concrete is not generally recommended where there is a high water table because the concrete will react with the water.
Thank you.
TXDOT allows crushed concrete to substitute for crushed limestone as flexible base material. Iowa highway dept. was using a lot of crushed concrete as base for Interstate highway reconstruction a few years ago and tying it into edge drains. I have always assumed concrete didn't care about water.
