quiz - can a DOL-start unloaded induction motor "overshoot" sync speed
If I were to perform a direct-on-line start a large motor with no connected load, would you expect the speed to overshoot synchronous speed?
(note the word quiz - that's a clue that I know the answer - just asking for fun)
RE: quiz - can a DOL-start unloaded induction motor "overshoot" sync speed
Keith Cress
This is not like a generator being driving by a large engine. The engine not having any real synchronous relationship could easily over shoot the generator.
All this is seat-of-the-pants conjecture..
Keith Cress
If instrumentation indicated an overshoot, I would seriously check the instrumentation and recheck the supposed overshoot with different types of instruments.
Bill
"Why not the best?"
Jimmy Carter
There are assumptions built into the torque speed curve...
I did a recording once showing that it can, indeed, overshoot. Especially it there is an inertial load and very little friction. The reason is that acceleration is quite high and that it doesn't go to zero immediately when you reach synch speed.
That is also why an induction motor can oscillate around zero 'pole angle'.
I will either find that recording, or make another one.
Gunnar Englund
www.gke.org
But I still haven't revealed my explanation (no, not really mine... Krauss' explanation although I'd be happy to take the credit).
The assumption built into the torque speed curve?
Gunnar Englund
www.gke.org
Attached are some excerpts from Krauss' "ANALYSIS OF ELECTRIC MACHINERY AND DRlVE SYSTEMS" 2nd ed.
In slide 1 you see the characteristics of the motors studied for "free" (unloaded) acceleration. Curves of actual torque vs speed during acceleraiton are given for 50 hp motor (Slide 2), 500hp motor (slide 3), and 2250hp motor (slide 4).
On slides 3 and 4 the steady state torque-speed curve is plotted on the same axis. If we imagine the transient progressing vs time, the actual torque is lagging behind the steady state torque... it never reaches the breakdown torque and it is slow to return to 0 (has not returned to 0 yet when we reach sync speed).
The reason is that the rotor current decays with a rotor L/R constant which is relatively long for high horsepower motors (designed to have good efficiency and therefore low rotor resistance). If we are steady state at sync speed we have zero rotor current and 0 torque. But if we rapidly accelerate to sync speed, rotor current has not yet decayed to 0 and there is still accelerating torque even at sync speed.
I have to admit I was very surprised by this also – never heard of it until today. The torque speed curve is so familiar that I guess I forgot about the steady state assumption built into it.
I think it is relatively common in motor starting studies to simply read the torque off of the torque speed curve (that's what was done at our plant). That approach in my mind is similar to a "quasi-steady-state" approximation because it borrows steady state results to apply to transient simulation. The error is small if it is a small motor because with the high L/R the actual torque reaches steady state torque very quickly. I think the error is also smaller for loaded start than unloaded start because the speed changes slower. But for unloaded start of a large motor the steady state torque curve is a pretty bad approximation of actual torque
Thanks again.
Bill
Bill
"Why not the best?"
Jimmy Carter
I was a commissioning engineer at Siemens back in the early seventies. At that time, there were no fast frequency inverters, so the test rig for fast compressors that I was starting up had Ward-Leonard systems that fed a DC motor with a multi-pole three-phase generator. The WL system excitation was controlled by a PWM DC amplifier which was controlled by a standard speed controller.
I was fairly young at that time. But had been working with variable drives in the Swedish Army, at ASEA (now ABB) and Siemens for almost ten years, so I thought that I had seen it all already (little did I know).
Anyhow. I couldn't make that drive stable. It oscillated constantly with a low amplitude and a rather high frequency - something like 10 Hz, if I remember correctly.
Nothing could stabilize it. All the standard tricks were of no use. I finally replaced the speed controller with a fixed voltage source that excitated the WL directly. Oscillation still there. To rule out the suspicion that the WL was unstable 'in sich' (sorry, German company), we got ourselves a set of forklifter batteries and ran the DC motor from that. Oscillations still there. Munich was now engaged (the system had been designed there) and a Doktor-doktor plus a staff of technicians arrived with a van full of instrumentation.
A very thorough test followed. One interesting test was to record the speeds of the generator and the induction motor. We clearly had an unstable system. It was ringing loud and clearly and the 'steady state' assumption inherent in the speed/torque curve of the induction motor was scrutinized in detail. Hey! This was research - and I loved it.
The quick fix this time was to add inductance in the only available path, the connection between generator and induction motor. The inductance consisted of three 35 mm2 Cu cables that were laid in coils with 50 turns and around 600 mm diameter. Not that we really could prove mathematically that it would work. It was what was available and it worked the first time.
The DOL overshoot is something I could see on a much later occasion. I shall look for that recording. Or, if necessary, make another one. The instrumentation to do it is much more userfriendly these days. Problem: Finding an induction motor with an encoder that is DOL started (the motor, I mean).
Gunnar Englund
www.gke.org
Do you have a DOL induction motor with an encoder?
If so, I could send you my fast encoder decoder (works with reciprocal frequency measurement). It makes fast speed recording possible. I even was able to record longitudinal transients in a sheet of steel in a cutter with it.
There is a short description at http://ww
Sorry, only in Swedish, I really have to do something about that. The last picture shows step response. It is around 300 microseconds in this case. It can be made faster, if needed.
Gunnar Englund
www.gke.org
I think that Pete will find out using one of his math tools. Stand by!
Gunnar Englund
www.gke.org
Am I correct in visualizing an induction motor hunting, where the frequency excursions due to hunting are more than twice the slip frequency?
Bill
"Why not the best?"
Jimmy Carter
Rather than inertia being the source of the overshoot, rotor inductance is the cause of the overshoot. Inductance is a property which makes a current want to keep on flowing at the same level unless energy is added/removed from the circuit. If you plotted used the steady-state current-vs-speed curve and added to it a plot of actual current vs speed during the transient, the steady state current would decrease faster than the actual current (in the neighorhood approaching sync speed) because the inductance limits how fast the actual current can decrease.
Gunnar - we don't have any multi-pulse-per-rev gear type encoders on any motor driven equipment (I think we have them on our main turbines for torsional montioring). We do have a few large motor-driven machines with keyphasor (one pulse per rev) as part of Bentley Nevada vibration monitoring. I never looked closely for speed indication output from those devices, but I will check. We also have the ability to capture vibration time waveform at startup with high sample rate using our walkaround vibration data collectors.....that is a little bit less direct indication of speed, but I think I could estimate speed reasonably well from there. We'll see what opportunities present themselves.
waross -
It is interesting to observe that the torque applied between the stator and rotor of an induction motor acts like a damper (related to rate of change of rotor position - and in fact directly proportional to rate of change of rotor position if we linearize about the operating point). In contrast the torque applied between stator and rotor of a sync motor acts like a spring (proportional to rotor angular position).
So an induction motor model would look as follows:
Stator === Field/Damper === RotorInertia
If the entire machine inertia acts rigidly, there is no oscillating frequency inherent in the above "mechanical" system. If you perturb it, it will just slowly settle toward equilibrium position rather than oscillating.
In constrast for sync machine the field plays the role of a spring. Armotrisseur windings do play the role of a damper so we could call it a damped spring, but the damping factor is low. So a sync motor model would be:
Stator = Field/DampedSpring ===RotorInertia
If you perturb it from initial position it will experience decaying oscillations (assuming damping is less than critical damping). Much different than induction motor.
Now there are plenty of other oscillations that can occur. If coupling acts as a flexible spring, then the motor inertia and driven-load inertia can move in opposite directions and oscillation can occur. Also if there is any controls associated with he power supplied to the motor (various types of vfd), new possibilities for hunting are introduced.
So there are a lot of possibilities for hunting. At least one of them is eliminated due to the damping effect of induction motor and absence of any spring action between stator and rotor. I tend to think in general induction motor is less susceptible than sync motor because that damping damps many different types of oscillation. I don't have a lot of experience with any hunting problems... just my thoughts fwiw.
The rotor circuit has a relatively long time constant and for a short period of time (relative to the rotor time constant), the rotor appears to have constant excitation.
If the rate of acceleration is higher than the rotor time constant, then as the rotor approaches synchronous speed, there will be a period where the rotor is "over excited" relative to the speed it is operating. It is thus able to behave like an over excited synchronous motor and ocsillate around synchronous speed.
Best regards,
Mark Empson
L M Photonics Ltd
Oscillation is undamped ringing. Put some velocity dependent losses in the system (first derivative) and you have a system that overshoots when subject to high acceleration.
Pete is the one most versed in math. Looking forward to an analytical explanation.
Gunnar Englund
www.gke.org
Another way to look at it is that we have a control loop with a target speed of 30hz. The rotor current is part of the feedback comparing actual speed to target speed. Since there delay (due to inductance) in the rotor current feedback, we have overshoot and oscillation.
It would not apply to smaller motors since they have lower L/R (for example see the 50hp startup curve in attachment above - no overshoot). It would not apply to vfd start since the speed is slowly ramped. It would not apply to slip ring motor if: 1 - speed is increased slowly, or 2 - motor is small. If there is large slip ring motor started DOL, I suppose it's a possibility although I think rotor resistance is higher for slip ring motors than squirrel cage motors.
I was able to do a simulation which matched the results posted. I will posts some results from there to show a slightly different view: speed vs time and torque vs time. The thing that confuses me a little bit is the time constants. For this 2250hp motor with R2' ~ 0.02, XL2' ~ 0.2, Xm ~ 13, which has L/R on the high (long) end of the spectrum, it still seems to have a fairly small/short time constant. Using the the rotor leakage inductance:
Rotor L/R = L'/R' = Xl' / R' /(2*PI*60) = (0.2/0.02) / 377 ~ 0.025 sec.
That seems relatively short in comparison with the transient and the oscillation a..........
Now if for some reason you included Xm in the ratio the time constant would be a lot longer (but it's not obvious that should be included)
Rotor L/R = L'/R' = Xl' / R' /(2*PI*60) = (13/0.02) / 377 ~ 1.5 sec.
At this point it doesn't quite make sense to me - I can't reconcile the time constant with the transient. Maybe my question will be clearer to readers when I post the plots vs time (maybe tonight).
[/quote]
Gunnar Englund
www.gke.org
First picture: nominal parameters, normal start-up.
Second picture: inertia reduced by a factor of ten.
Third picture: Additionally, the rotor resistance reduced by a factor of ten. Has this kind of growing oscillations been observed with real motors?
Yes, it does exist IRL. Only, our oscillation didn't grow limitless. It stayed within a few percent amplitude.
This thread is getting better and better!
Gunnar Englund
www.gke.org
The oscillation will certainly be larger if you decrease rotor resistance and/or inertia. But continually growing oscillations seem impossible to me (I'll bet if you continue the simulation it will level out and eventually start decreasing and if long enough return to steady state).
This conclusion is based on looking at the motor start event in the synchronous ref frame (which is a very interesting and informative excercize). In the sync reference frame, we have similar a pair of stationary (sync frame) magnets representing the stator field. Initial conditions: at the moement of start we know in our normal reference frame the rotor is at rest, but in the sync ref frame the rotor is rotating at 3600rpm (2-pole motor) the moment before start. Then the magnetic fields induce circulating bar currents which will slow down the motor. Conservation of energy tells us that by the time the rotor comes to rest in the sync frame (up to sync speed in our normal ref frame), the I^2*R energy dissipated by the rotor must equal the initial kinetic energy of the rotor (correspondin to 3600rpm). (This also correctly predicts the amount of energy dissipated in an unloaded motor during start by the way). Once the energy is dissipated in the rotor resistance, there is nothing to sustain the oscillation and it must eventually disappear (otherwise we have a perpetual motion machine).
By the way, what is ATP?
Gunnar Englund
www.gke.org
Slide 1 are machine parameters.
Slide 2 is torque vs speed – same as was shown in Krauss.
Slide 3 is speed vs time
Slide 4 is Torque vs time
(oscillations in speed and torque occur at 7-8hz and decay quickly)
Slide 5 is stator flux linkage (lambda) along the q axis in sync ref frame
Slide 6 is stator flux linkage (lambda) along the d axis in sync ref frame
Slide 7 is rotor flux linkage (lambda) along the q axis in sync ref frame
(This is the only one of the 4 flux linkages that shows the oscillation!)
Slide 8 is rotor flux linkage (lambda) along the d axis in sync ref frame
Slide 9 is stator current along the q axis in sync ref frame
Slide 10 is stator current along the d axis in sync ref frame
Slide 11 is rotor current along the q axis in sync ref frame
Slide 12 is rotor current along the d axis in sync ref frame
(oscillation shows in both stator and rotor current in q axis only)
Slides 13-15 are stator currents transformed to the normal (stationary) reference frame
I think there are at least three interesting things to talk about.
ITEM 1: OVERSHOOT OF SPEED AND SUBSEQUENT OSCILLATION
(the main subject of the thread).
Krauss makes the statement that these are the result of a rotor electrical transient. He "proves" this in the chapter on "reduced order models" by doing a reduced-order simulation which NEGLECTS stator transients but includes rotor transients. The overshoot and subsequent speed oscillation is still there in the results of that simulation and therefore not a result of stator transient and must be a result of rotor transient. The reduced order model can be solved for eigenfrequency of about 7-8hz.
If I look at the results of my simulation slides 5-8 are 4 flux linkages in the q and d axes for the stator and rotor. The oscillation only shows up in one of the four – the rotor q axis flux linkage. I guess this is consistent with the fact that the overshoot originates from rotor transient. I'm not sure what we learn from the fact that it's associated with the q axis as opposed to d axis. When we look at stator currents (slides 9 through 12), we see the oscillation shows up in the q axis current of both stator and rotor – I guess the stator current oscillation is a result of the transient rather than an initiator. Although when we look at the normal stationary-frame abc stator currents in slides 13-15 it's very tough to see the oscillation there.
ITEM2: SLOW OSCILLATING DC ADDED TO LRC ENVELOPE DURING THE FIRST SECOND
See slides 13 – 15. Look at the top and bottom of the envelope and you see they move up and down together indicating some added dc component. The envelope of the LRC slowly varies up and down.
Krauss says it is due to interaction of stator electrical transient and rotor electrical transient (whatever that means... hard to visualize... don't see it in the flux linkages). If anyone can provide a better explanation I'd be interested to hear.
The interesting thing is I have observed similar oscillations in recorded motor start information on a very similar motor (2500hp, 1800rpm, different voltage=13.2kv). (If anyone wants me to post that let me know). I have wondered about it before - now I know it is nothing abnormal - it is expected. This particular item is apparently not limited to large / high-efficient motors – it also shows up in Krauss' simulation of a 3hp motor start.
ITEM 3: 60HZ TORQUE OSCILLATION IMMEDIATELY AFTER START (NEAR ZERO SPEEED).
This is shown in slides 2 and 4 (also a slight speed ripple shows up in slide 3). Krauss says this is due to the transient dc decaying offset of the stator currents. In the chapter on reduced order models he simulates the start with stator transients nelgected, and this initial 60hz torque oscillation is mostly absent (which sort of proves it is caused by stator electrical transient). Now it's interesting to observe that the initial stricly-decayind dc offset is gone within the first 0.1 seconds (slides 13-15), but yet the 60hz torque oscillations last to at least 0.7 seconds (slide 5). I guess the relevant dc is associated with that weird slowly-oscillating dc of item 2? But it's strange because the envelope of the 60hz oscillating torque doesn't show any of the similar oscillation as shown in item 2... the 60-hz oscilating torque envelope just decays very smoothly to 0. Pretty bizarre.
I can't say I have ever seen evidence of 60hz oscillating torque during start although I wouldn't know what to look for. If there were a 60hz torsional resonance it could be briefly excited. I guess this is not so bad as the sync motor startup torque oscillations which vary in frequency from 120hz down to 0hz and can excite every torsional resonance in between.
The induced voltages in any reference frame can be expressed as a sum of a speed voltage and a d/dt(Lambda). Transients are associated with the d/dt(Lambda) term. Reduced order simulation discards the d/dt term - sort of like a quasi-steady state analysis. Good enough for most purposes and significantly reduces the compuation time.
I have been looking at the frames and your comments. The reason why you do not see any oscillation in Id is, I think, that there is no energy exchange involved between Id and the pole angle oscillation. Simply because there is no torque produced by Id, only EMF (remember our discussion about Back EMF?).
The oscillations shall only show in Iq, because that is where the "spring", i.e. elastic coupling, between rotor and stator flux is and that "stretching/relaxing" the spring influences the current.
A great thread, this is. I will look further and try to understand what is happening. Did you ever try ATP? I think you should. I registered and received the package. But it takes some time to get started with it. And I don't ever seem to get that time
Gunnar Englund
www.gke.org
The applied stator voltage in my simulation was on the vq axis in the sync ref frame. So it would make sense to me that Iq is in-phase with applied voltage and therefore associated with real power (associated with non-zero average torque) and Id is associated with changes in stored magnetic field energy. Is that correct?
Even if that is the case I don't see that this necessarily proves why Id is not involved in transient torque. Look at the instantaneous torque equation:
Te = (3/2) (Poles/2) * (Lamba_q*I_d - Lambda_d*I_q)
I believe the steady state torque is associated with Lambda_d*I_q. But the transient torque also includes contributions from Lambad_q*Id. So it is not immediately obvious that Idr would be necessarily be excluded from torque oscillations.
For my present purposes, I am happy using Matlab or excel for solution of O.D.E. initial value problems. It is a very general solution method applicable to a very wide variety of problems and I am already familiar with it. I may eventually look at ATP if I find the need for a very large simulation or if I need to double check results of a model.
I noticed ijl's simulation also shows small speed ripples during the early acceleration - evidence that his model also predicts those line frequency torque oscillations immediately after start (item 3 above).
