Terms relative to Press work
is there anyone can give me the definition or explaination about the terms below:
Shell Press
multi die
multi die tooling
die shoe
conversion press system
RPT
SOT
thank you.
RE: Terms relative to Press work
Shell Press : A Press to used to punch out round shapes for later use in draw dies?
Multi die : A die with multiple inserts or may be a Progressive Die?
Multi die tooling: The inserts going into a multi die to produce different forms of a similar part?
Die Shoe : a Ring or "Shoe" from cold rolled Steel surrounding a hardened die section or sometimes holding together a cracked die for extra stength?
Conversion Press System : ???? Could be just about anything.
Shell Press, in the old days it was a large custom press used to make artillery shells. But I think you are asking about Clam Shell Presses. They are small table-top units, used for bagging and packaging products.
Die Set = Die Shoe (usually an upper and a lower make a set)
CODE
Conversion Press is usually a high speed press used in the beverage industry to make can ends.
Forging http://mech.e.tripod.com
Ddraig Breuddwydia....www.tailofthedragon.com
