SQL and MS ACCESS VBA
i have a little bit trouble with MS ACCESS VBA. I have this code:
DStr = HeldaniFirmy & "*"
Set DBS = CurrentProject.Connection.Execute("SELECT Firma, IC, Mesto, Zeme, TelFa, www, kategorie, popiscinnosti, faxfa, obrat, KompassKod, PocetZamestnancu, Poznámka, Odpovědná_osoba, Kontaktovat, AktualniKontakt, SoucasnyKlient, MinulyKlient, pase FROM tbl_firmy WHERE ('" & PrenosMest & "' AND Firma = Like " & DStr & ") ORDER BY Firma", , adcmdtext)
But i can not convince VBA to work. Variable DStr (it is string) I want to enter first a few letters and I need the questiun return me every records which start with entered lettes.
Could somebody help me what is wrong and how Can I do it correctly?
Thank you
RE: SQL and MS ACCESS VBA
what is PrenosMest?  The SQL reads something like
CODE
SELECT ... FROM ... WHERE 'xxx' AND Firma = like FRED ORDER BY Firma
Try this to start then add in your PrenoMest bit later
CODE
Set DBS = CurrentProject.Connection.Execute("SELECT Firma, IC, Mesto, Zeme, TelFa, www, kategorie, popiscinnosti, faxfa, obrat, KompassKod, PocetZamestnancu, Poznámka, Odpovědná_osoba, Kontaktovat, AktualniKontakt, SoucasnyKlient, MinulyKlient, pase FROM tbl_firmy WHERE Firma  Like '" & DStr & "' ORDER BY Firma", , adcmdtext)
