How to make tapered helix on msc patran
I am not able to make tapered helical screw on MSC Patran. I am able to make the helix but I am not able to make tapered helix.
Also, I am making a triangular surface, now with the rotation of the helix the angulation of the tip of the triangle changes i.e. the the surface is not parallel to the guiding curve.
Hope you could understand my problem and help.
Mani.
Mani.
