Elastic curve
Elastic curve
What will be the elastic curve of this beam
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Elastic curve
Mike McCann
MMC Engineering
RE: Elastic curve
RE: Elastic curve
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
RE: Elastic curve
RE: Elastic curve
I assume the OP is asking how to arrive at the answers that are given below.
The problem has its basis in the elastic theory of beam bending. Please see attached scan for some information regarding this. Also:
h
This walks you through the whole thing.
RE: Elastic curve
Mike, I also haven't seen this notation before. I just realized doing work from softwares only made me loose o basics of statics. So I started to study own my own to take the rust off. I am trying to solve this with moment area method. Can you draw out elastic curve for this or try to solve it ! !
KootenayKid
How can you change this to fixed end etc? I do not buy that
RE: Elastic curve
As with the beam restraint conditions i think they are both s/s roller support allowing lateral movement (no moment at this point due to it being simply supported.
Try drawing out the deflected shapes and approximates of the bending moments to see whats really happening.
lt.
this may shed some light on the problem:
http:/
As with the beam restraint conditions i think the one on the left is a s/s roller support allowing lateral movement (no moment at this point due to it being simply supported), and the other end is fixed end roller support.
Try drawing out the delfected shapes and approximates of the bending moments to see whats really happening.
Please keep us posted on your progress i shall also have a go at finding a solution
RE: Elastic curve
PST
RE: Elastic curve
The spread sheet gave me the shape of elastic curve and after that it was easy. Got all answers matched.
RE: Elastic curve
You don't buy my method????
Your problem is statically determinate. You can work out the moment diagram in about 30 seconds flat. If you work out the moment diagrams for your example, and for the simplification that I suggested, you will find that they are identical. And, if the moment diagrams are identical, then so are the deflected shapes.
You could have solved this by the superposition of a couple of formulas straight out of the steel manual.
RE: Elastic curve
End A is pinned so theta A has value and matches the answer.
If I make it fixed than as per your method theta A = 0
How do you justify that?
RE: Elastic curve
See the sketch attached. At least I think that I've attached a sketch (I've never done it before).
I reversed the node lettering when I described the method in my intial post. You are correct of course, point A will have a rotation.
The trick to the simplification is to realise that it is only the relative displacement between ends that matters. Whether it's the pinned or guided end that does the actual travelling, is irrelevant.
RE: Elastic curve
Thx.
BMD is same for all these.
But elastic curve for your cantilever will not match the elsatic curve of my problem. In my problem it becomes horizontal ar support B. U can x-check with prex excel sheet above. But in typ cantilever the elsatic slope is sloping away ! !
RE: Elastic curve
BA
RE: Elastic curve
I was able to solve it with moment area method. I was also able to verify my BMD with STAAD once I placed the right D.O.F's
RE: Elastic curve
In a flexural bending problem, if the moment diagrams are the same, the elastic curve is the same. There's just no getting around that.
Just imagine: you could also solve the problem by double integration. And, when you performed that double integration, what you'd be integrating is the moment diagram. Same moment diagram --> same deflected shape
My method results in zero slope at node B as well. How could it not, I've got that node completeley fixed??
RE: Elastic curve
I misinterpreted the support at point B. Using Mike's interpretation, the problem is easy.
BA
RE: Elastic curve
One more thing: in a typical cantilever, the slope is most definately not sloping away from the support. It is, by definition, zero slope at the support.
RE: Elastic curve
In your beam point B is fixed so not going anywhere.
In my problem this point rolls down and gives deflection.
See ! same BMD but different elastic curve.
RE: Elastic curve
That's my whole point. It doesn't matter whether point B rolls down or point A tranlates up. It's only the relative deflection between the beam ends that matters for defining the elastic curve.
If you solve the problem by our respective methods, you will find that my cantilever tip deflection at point A exacly matches your guided end vertical translation point B. And, more importantly, the slopes and relative deflections will be identical at all points along the beam.
RE: Elastic curve
OK I will do it when I have time. Got to do some office work also. To me it looks more of a coincidence like 2x2 = 2+2 but not in general form. The defelction of cantilever tip will not match with guided rotation.
RE: Elastic curve
BA
RE: Elastic curve
RE: Elastic curve
I checked and answers of your beam are correct.
How did you figure out this beam ... conjugate beam concept. was never a big fan of it. Any way tip of cantilever still point down contrary to guided roller but perhaps that is ignorable difference here.
RE: Elastic curve
Thanks for going to the trouble of checking.
The solution doesn't use the conjugate beam concept, at least not as I understand it. The method simply uses superposition of two basic load cases combined with the recognition that my simplified model and your original one are statically equivalent.
If you load the cantilever with an upward force at point A and a downward force at midspan (to match your model exactly), you will find that the cantilevered tip points upwards, just as you would expect it to. There should be no difference, negligable or otherwise.
That's basically what I showed in the middle diagram of the sketch that I attached to my previous post. I only flipped the loads around in my third sketch to make it look more familiar. Perhaps that muddled my explanation rather than clarifying it.
RE: Elastic curve
RE: Elastic curve
A simple beam of length 2L with load W placed L/2 from each end is symmetrical and each half has precisely the same elastic curve as the beam in this thread.
BA
