Acad 2007 with Vista 64 bit
Does anyone know how to run Acad 2007 on Vista 64 bit system? What Marks625 suggested seams to work, but i can't register the product (for the activation code) because it locks up at one of the pop-ups, when i hit next. If i don't register it, it runs fine, but you only have 30 days. A couple years ago Marks625 wrote:
Someone else must have had this problem or is just about to.--------------So I bought a new computer on Sunday. It came with Windows Vista. The very first thing I did was load ACADLT2007.Here is what happened:Install ACAD....Try to start program....Program won't runun-install program....re-boot....re-install program....Still won't rununinstall program....re-boot....turn off PITA Norton....re-install program....still won't runThink....Think....ThinkRemember the compatability issues when XP came out? To get ACADLT2007 to run in Vista here is what I did:Go to the acadlt.exe fileRight-Click on the fileGo to the Compatability TabCheck-Run the program in Compatability Mode for Windows XP(SP2)Click on Show settings for all usersCheck-Run this program as an administratorClick Apply and Ok back outProgram runs fine :)I hope this helps anyone as frustrated as I was that ACAD might not yet be compatable with Vista.Mark SchroderDesign EngineerMcKean & Associates Engineers
RE: Acad 2007 with Vista 64 bit
