Adding center lines in pro e drafting
I know these is just simple but I tried myself to explore and can't find. Thanks to these site, I know somebody can help. how to add centerlines in 2d views in pro e. Once again, thank you much.
cgelang
cgelang
RE: Adding center lines in pro e drafting
Once you have this open select the axis button(._._._A_1). Then select your prefered "Show By" method and follow the message boxes for finishing.
Hope this helps.
