adding bended and flat pattern in pro/e
Is it possible to add bended part and a flat pattern in a single/same sheet page, I tried but can't find. If somebody knows, can I borrow your idea please. Thanks in advance.
cgelang
RE: adding bended and flat pattern in pro/e
You can if you create a family table of the part bent & flat.
Then, in the drawing right-click on the background, select Properties -> Drawing Models -> Add Model
select the family table part, and you can now add it to the drawing - please note that the new view comes in at a DIFFERENT scale to the existing views.
Thanks robertib, for your help!. You're are right, family table is the answer, I did it.
cgelang
