Are residential hydronic boilers required to be ASME H stamped ?
Can anyone tell me if a hydronic boiler, if used in a private residence is required to be ASME H stamped if it is used on an open vented system i.e. atmospheric pressure ? Or are there exemptions ??
RE: Are residential hydronic boilers required to be ASME H stamped ?
http://www.nationalboard.org/ViewOurMembers.aspx
