combustion temperatures
Hi! I'm working with a hot gas generator that uses heavy fuel. We wanted to know what is going to be the temperature that the gas generated will have. We did the calculation using the stoichiometric composition and we found around 1950°C (with 0% excess air), however when we talked with our burner provider he told us that the temperatures where much more higher. We where considering to have at least a 20% excess air but since we are not sure if our calculation is correct we dont know if the temperatures will be correct.
Could someone tell me a good way to calculated this temperature and also if you know of a calculator that I could use (website, applet, etc.)
Thank you for your help!!!
RE: combustion temperatures
From old statistical data in my antiquated notes the flame temperatures are never adiabatic because heat is transmitted in "status nascendi" to the colder parts of the heater (tubes, etc.).
Nevertheless, the flame temperatures for fuel oil are approximately as follows (the 0% xs air column gives the adiabatic flame temperatures):
                                       t,oC
                     heat radiated as a fraction
 xs air              0         0.2       0.35       0.50
   %           (adiab.)
  0                2000    1720      1460       1160
20                1800    1520      1270        990
40                1640    1360      1140        880
60                1480    1230      1010        780
The heat released by the burners (including any air preheat), the degree and type of atomization, the geometry of the combustion chamber and of the heat-absorbing surfaces may affect the amount of radiated heat. I think there is a formula by Hottel to that effect.
The enthalpy of the combustion gases for a typical fuel oil in kcal/nm3 (n=normal conditions, 0oC and 1 ata) -taken from an old graph- are approximately as follows:
 xs air
   %         kcal/nm3
   0              860
 10              790
 20              720
 30              670
 40              620
 50              580
These figures are valid for fuel oils with low calorific values ranging from 9500 to 11000 kcal/kg. There exists also an old graph by Rosin-Fehling that gives the enthalpy of the combustion gases for all kinds of hydrocarbon-based fuels as function of their temperatures.
Thank you for your answers.
Could we consider that the flame temperature and the gas temperature are close one to the other? In fact I need this info so we can design the hot gas chamber that goes just after the burner. Since the properties of the refractory bricks can change drastically from one temperature to the other I need a good estimate of the temperature to make my choice.
The same old notes refer to the wall temperatures for two different heat loads per unit volume of the combustion chamber:
 Heat release                  temperatures oC
 kcal/(m3.h)      nearest to burners     farthest
  225,000                        1400                1250
  150,000                        1250                  850
IMHO, the design of process fired heaters should be done by experienced companies, such as Broach, Sigma, Enercon, to name just a few.
Thanks a lot for your help, I will look into it and will tell you how it went.
Ok, I checked the values and when we do the stoichiometric combustion we have more or less the same values, around 2000°C, however this is when we do it with 0% excess air, the moment we include the 20% excess air we go down to 1750°C. This is the gas temperatures and not the flame temperature. Does this sound logical to you?
We are using the q = m*cp*dt formula to do our heat balance (in and out) and it all adds up but we still aren't sure about the temperature
Can the gas temp be different than the flame temp for more than 200°C?
Thanks for your help!
Could you tell me from where you got your notes for the temperatures?
                                     t,oC
xs air              0         0.2       0.35       0.50 %               (adiab.)
I get the good values according to this table, could you tell me where you got it so I can use it as a reference?
thank you for your help
Thanks!!
