Finned Tube Heat Exchanger Design
I am trying to find some good online sources for designing finned tube heat exchangers. The best source I have so far is "Compact Heat Exchangers, W.M.Kays and A.L.London", which is very good however it is quite a brief text.
There seems to be very few examples for designing this type of heat exchanger.
Can someone point me in the direction of some good text for designing a finned tube heat exchanger?
Thanks in advance.
Thanks in advance.
RE: Finned Tube Heat Exchanger Design
http://www.wlv.com/products/databook/databook.pdf
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Thank you very much for your reply. This link was exactly what I was after, and has proved very useful.
Thanks for taking the time to show me this.
James Spisich
Design Engineer, CSWP
Made things a bit confusing until I figured out what he had done wrong.
(used incorrect value for viscosity)
