Required Safety Valve Flow for a Centrifugal Compressor
I have been struggling to find a generally accepted standard for sizing a centrifugal compressor discharge safety valve.
The basic scenario is "blocked discharge".
The only thing I have found written is in the Air Compressor Industry (The minimum flow at Surge & 105% speed).
Most folks casually cite maximum flow at stonewall.
But in my thinking, this is a double contingency -- blocked discharge and rise in suction pressure.
At semi-normal suction conditions stonewall does not generate enough pressure to activate the safety valve.
Besides, why would a compressor stonewall when the discharge is blocked.
Any comments would be appreciated.
RE: Required Safety Valve Flow for a Centrifugal Compressor
If the blocked discharge allows the suction pressure to rise, then you have to consider it.
If I've sizing/evaluating a relief valve I'm trying to prevent something from being overpressured so sizing for stonewall doesn't seem to make any sense to me, back towards the surge line would make more sense to me. The relief valve could also be sized I guess to maintain a minimum flow through the unit but unless the suction contitions are sufficient stable, coming up with a set point could be tricky.
This sets the outlet pressure.
For the inlet pressure you will have to look upstream. If this is the first compressor then you must use inlet PAHH i would think.
With regards to speed: Is it a VFD? If yes then i think you should use the max. allowed speed that would give the highest flow rate (not nescessarely max speed since it could be limited by stonewall).
Best regards
Morten
for your comments
