Interpolating
Interpolating
Interpolating
I have to vectors (flow and pressure).
I am scatter plotting them (flow vs pressure). I did it before, I do not recall how I interpolated around for a certain value of let say pressure and have the flow value on that specific point...
hope anyone can help me, thanks
RE: Interpolating
Have you tried linear interpolation?
RE: Interpolating
is it interp2?
I will try tomorrow morning
RE: Interpolating
Do you want an interpolation or a best fit line?
use "polyfit" for the latter
M
Dr Michael F Platten
RE: Interpolating
Interpolation
RE: Interpolating
I'm sure there are some built in excel functions that's do what you want.
Personally rather then worrying about that syntax I would rather just write the formula.  Then you can do the same thing in Matlab or Maple or whatever.  Math works in any language.
Step 1:  What is the slope of a line passing through two points: (X1,Y1) and (X2,Y2).
Think about it before you read the answer.
Answer:  slope = (Y2-Y1)/(X2-X1)
Step 2: How do I use that slop to find the value of Y at some arbitrary X in the interval (X1,YX)?
Answer:
Y = Y1 + slope * (X-X1)
Sorry I am not trying to be a jerk.  It is something you should spend time understanding (rather than memorizing) imo.
RE: Interpolating
obvious typo correction in bold:
Quote:
Step 2: How do I use that slope to find the value of Y at some arbitrary X in the interval (X1,X2)?
RE: Interpolating
I apologize if I have underestimated your problem. Maybe you want a general formula to work with two columns of X, Y data.  Then you need to use some lookups if you are going to build the arguments for the interpolation formula if you are going to build it yourself.
RE: Interpolating
Here is a vba function to return the interpolation from a range of X's and Y's:
CODE
Function InterpL(LookupValue, KnownXs, KnownYs)
Dim pointer As Integer
Dim XO As Double, YO As Double, X1 As Double, Y1 As Double
pointer = Application.Match(LookupValue, KnownXs, 1)
XO = KnownXs(pointer)
YO = KnownYs(pointer)
X1 = KnownXs(pointer + 1)
Y1 = KnownYs(pointer + 1)
InterpL = YO + (LookupValue - XO) * (Y1 - YO) / (X1 - XO)
End Function
RE: Interpolating
And yes this is linear interpolation.  For a higher order interpolation you need a spline technique.  Let us know if you are interested in that.
RE: Interpolating
Hmmm.  I thought I was in the excel forum - hence the vba function.  IRStuff sent me off track (or maybe I just wasn't paying attention).
Use interp1 for simple interpolation like you are talking about.
Interp2 is for 2-d interpolation.
There is a lot of help in the help
RE: Interpolating
If you are using interp1, be sure that your independent axis (you haven't told us whether it's pressure or flow) is monotonic.
- Steve
