error updating views
Has anyone ever seen the error: FUNCTION NOT SUPPORTED FOR GENERAL BODIES In IDCOEN?
This happened while attempting to update views after a minor drawing update. It no longer shows to be out of date but the views did not update.
RE: error updating views
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
After speaking to the designer that worked on it last he said he got the same error and he had to go through the assembly removing one component at a time and attempt to update the view till he found the problem file.
He can't remember but I assume he removed the problem file and then was able to update views... In any case, the issue evidently has not been solved. I am thinking that he did not fix the problem file but just put it back in after he had updated views???
John R. Baker, P.E.
Cypress, CA
