NX6 .prt to TCVis 2007 .jt translations - limit of components used?
Quick question - if I am attempting to run a translation of NX6 .prt files to TCVis 2007 .jt format - is there an upper limit of the number of .prt files that can be translated via the run_ugtopv program?
RE: NX6 .prt to TCVis 2007 .jt translations - limit of components used?
What Version are you using and what sort of numbers of components are we talking about?
If you are to get stuck then what you could do is structure your larger assemblies in a more or less modular fashion to create a small number of top assemblies under the main "master" assembly. If you have four such modules you're effectively quartering the task, and then you'll find that you can create four JT assemblies and add them into a master JT file manually.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Best Regards
Hudson
www.jamb.com.au
