high pressure piping and Bourdon effect
Hi all
I have to analyse feedwater pumps piping according to B31.1. Design pressure of discharge pipe is 23.4 MPa. Calcs during FEED was made by another company using Caesar II. They calculated standard operating cases W+P1+T1 but Bourdon option was set to "none" which results in no displacements due to pressure. While recalculating system in Autopipe I skiped pressure analysis to have the same as Bourdon effect = "none" in Caesar.
But I have doubts. B31.1 code is silent on including pressure elongation in analysis. Reason tells me to include bourdon effect, also my B31.3 experience incline me in that direction. But FEED calcs was made by big, international, German originated company with "thousands" years of experience in power. Maybe they are right.
The main problem is with pump nozzle load. When Bourdon is triggered on it is impossible to keep loads within allowable without significant routing change. I wonder what client will say as in this particular system only valve and strainer weight/length was changed since FEED.
Could someone give me a little piece of advice?
papiesz
papiesz
RE: high pressure piping and Bourdon effect
In my (quite outdated) experience, it is customary not to include pressure strains in the analysis, though there is no rational reason for that.
See what a bibliographic reference (also quite oldish...) tells about that:
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Could it be that in the slide-rule days of my youth, the Bourdon analysis was simply too time consuming and too rarely material to ever be done, so today when it is just a check box people still don't do it since it is rarely material?
It seems like if there was anywhere that piping would try to straighten out under applied pressure it would be on a feed pump discharge. If I was you I would get an authoritative answer from somewhere before ignoring your analysis that adding that analysis will over stress the pipe, but at the end of the day that answer should be in writing and signed by an engineer (from the German Firm I would think).
David
I meant elongation of straight pipe and elbow centerline under internal pressure. As I know Bourdon effect is linked with tendency of pipe bends to open under pressure. Ovalisation (if exists as a result of fabrication)intensify that tendency.
Pipe stress software (autopipe, caesar) can consider both fenomenon: straight pipe elongation and bend opening. Options are called translational and rotational Bourdon effect. In caesar you can build operating case that consists pressure but Bourdon can be set in three different ways: none, translational, translational and rotational together.
In calcs mentioned in original post it was set to none. In autopipe if you build operating case that contains pressure you have to consider translational Bourdon effect. So in caesar you can have case W+P1+T1 without any pressure effect while in autopipe not.
I simply wonder if that Germany originated company made it intentionally or by mistake. I know what is more conservative but I'm fresh in power I dont know common practices, but I do not want to be too conservative or dumb in terms of money.
regards
Papiesz
Have you tried contacting COADE / CODECAD with this question? Every time I talk to them they seem very knowledgeable. I am sure they could give good advice to get you going in the right direction.
Me, I would be inclined (if I had a non-run-limited key) to enable Bourdon effects and adjust the system until it passed, and then look at the ramifications in comparison to the system that passed without considering Bourdon effects. Then, once satisfied that both results were verified, the piping design I would propose or recommend would be the one with the Bourdon effects taken into account, and I would let someone else who might not like it prove to me that I was wrong.
Sometimes it's like the "project engineer's" approach to things (which I was in previous years). Sort of like, the best way to get the client to freeze the plot plan is to mobilize the piling contractor. (Did that once...worked like a charm.)
SNORGY.
L.C. Peng points out however that pressure stiffening is significant and that is why the B31 Codes have provided a "adjustment equation" to modify the flexibility factor for this effect.
Regards, John.
Thanks so much for this explanation, JohnBreen. Do you happen to know if L.C. Peng's book is available in Canada?
I'm heading straight from here to a Google search...
SNORGY.
Amazing the things I do on my day off...(Canada Day)...
SNORGY.
Hey, if you order it on "Canada Day" how could ASME possibly turn you down. You Canucks better not try asking them to pay the shipping just because of "Canada Day" though - bunch of tight hosers eh?
John.
SNORGY.
Lucky you, gentlemen
You can buy this book directly from ASME store. I come from Poland and I would have to buy it via English resseler which is 1.5 times more expensive and in addition he does not respect Polish credit cards. World more and more resembles jungle to me.
By the way I read Mr Peng old paper about interpretation of pressure elongation from www.pipestress.com (I think he is one of the authors of book mentioned by John). As I understand him, his opinion is the same as John's.
On the other hand Mr Peng provides equation from which pressure elongation can be calculated. For my parameters: 23.4 MPa, 150 C, NPS 8" Sch 140, pressure elongation is about 13% of thermal. It is rough calcs but indicates that pressure could play significant role when assessing nozzle loads.
papiesz
P.S.
Thanks to all for valuable posts
Pressure elnogation is not 13% of thermal. I made mistake, it is roughly 1/13 which is 7%. So it is less significant.
I'm sorry. This is because here is 11 PM, and I focus too much on my English instead of the problem.
papiesz
Bourdon pressure "expansion" results in contraction in the axial direction, which, if restrained, produces axial tension. As longitudinal stress is the result of Poisson's ratio x hoop stress, its much less than the hoop stress. Plotting these principal stresses on Mohr's diagram results in hoop stress (tension) far to the left and axial stress (also tension) between hoop stress and 0. The result is a lesser maximum shear stress than when Bourdon axial stress is not considered at all. Burdon "None" therefore results in a conservative design for a straight pipe, and going by what's been said above, for a curved pipe too. I would guess, probably from being the result of secondary effects.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
10's of newtons as opposed to the hundreds exterted on chain blocks to align pipework! Check out pump manufacturers requirements.
Brain
That is not true.
There is not any contraction due to pressure. Such situation exists in uniaxial tansion. You can observe it on tensile test machine where you can observe cross section area reduction.
In case of pipe you have membrane stress and strain state in which both streses are tensile. And both strain try to lengthen material. If you dont believe just put untied expansion joint in your piping.
By the way read your first sentence:
"...pressure results in contraction in the axial direction, which, if restrained, produces axial tension."
papiesz
I agree with you. Although pressure forces are rather in magnitude of hundreds they are far lesser than thermal and from earthquake and of course those which can arise during not carefull assembly. But you dont know Germans they are more strict than API 686.
papiesz
Strictly speaking, Big Inch is correct ... in that an element of internal pressure causes axial contraction. It is the poisson effect of hoop stress, which logically reduces axail length. This effect is however tiny in comparison with the the direct stain associated with axial pressure stress, which is of course tensile in the pipe wall with positive internal pressure.
Also w.r.t. Bourdon effect, I am fairly sure that Caesar II assumes an ovality ratio of 0.9 if the effect is specified. This is quite severe and would only normally be associated with pulled bends. The usual assumption with forged bends is that the Bourdon effect is aero in my experience.
Thats true what you saying about stress. But I mean strains
From mechanics of materials we have the following:
σH=pD/2t
σL=pD/4t
From Hooke's law:
εH=1/E(σH-νσL)
εL=1/E(σL-νσH)
let's assume that hoop stress is 2 (Mpa, ksi whatever you want)
axial must be equal 1
after substituting this into Hooke equation we get:
εH=1/E(2-0.3*1)=1.7/E
εL=1/E(1-0.3*2)=0.4/E
so we have elongation in both directions although as you said hoop stress reduces axial strains.
Thank you BigInch and others for discussion.
I think I will skip this Bourdon effect or pressure elongation.
regards
papiesz
