Weldment API Problem in Windows 7 x64
Hi, I know this is pretty new but I am using solidworks 2009 SP3 in windows 7 Build 7100 and a macro , the same one the api help files shows as an example, stop workind in this windows, even in vista x64 it works, Is there anyone with the same problem or maybe a solution. The code is this one.
thanks.
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swSelMgr As SldWorks.SelectionMgr
Dim swWeldFeat As SldWorks.Feature
Dim swWeldFeatData As SldWorks.StructuralMemberFeatureData
Dim boolstatus As Boolean
Sub main()
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swModelDocExt = swModel.Extension
boolstatus = swModelDocExt.SelectByID2("Structural Member1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
Set swWeldFeat = swSelMgr.GetSelectedObject6(1, 0)
Set swWeldFeatData = swWeldFeat.GetDefinition
swWeldFeatData.AccessSelections swModel, Nothing
it stop working in this line !!!!!!!
swWeldFeatData.WeldmentProfilePath = "C:\Program Files\SolidWorks_2006_sp0\data\weldment profiles\iso\pipe\26.9 x 3.2.sldlfp"
boolstatus = swWeldFeat.ModifyDefinition(swWeldFeatData, swModel, Nothing)
End Sub
RE: Weldment API Problem in Windows 7 x64
Did you get an error message when the macro stopped.
yes, Error '-2147417851 (80010105)':
Automation Error
A quick Google with those terms shows that error (in some cases) can be corrected by switching to late binding with objects ... whatever that means.
I found this too but couldn't understand, i have vista and win7 in the same computer and I tested the code on both, I was looking for a alternative, what i reaaly want is to change the weldment profile, if there is other ways I just need the vb command, the rest i can figure it out. thanks for helping, I tried to record a macro to see how it is done, but if I run the recorded macro it doesn't work..
When you declare a variable in VBA, you use the statement
Dim [varname] As [vartype]
When you declare an object variable, you can either tell VBA straight up what type of object you expect, like
Dim swApp As SldWorks.Application
or you can let VBA figure it out on its own by declaring like
Dim swApp As Object.
This makes VBA figure out what kind of object it has once it gets it.
If you use the second method, it's called "late binding".  The first method is called "early binding".  Each has its pros/cons.
-handleman, CSWP (The new, easy test)
I try to use late binding but the same error apears.. :(
make assembly from your part first
' Preconditions: Assembly document open that has part with a feature named Structural Member1.
' Postconditions: Profile changed to profile specified in macro.
Option Explicit
Dim swComp As SldWorks.Component2
Sub main()
'select your structural member
Set swComp = swSelMgr.GetSelectedObjectsComponent3(1, 0)
swWeldFeatData.AccessSelections swModel, swComp
boolstatus = swWeldFeat.ModifyDefinition(swWeldFeatData, swModel, swComp)
End Sub
It gives the folowing error.
error '-2147417551 (80010105)':
Automation Error
when trying to execute
P.S: I changed the Path to a valid one.
Debug.Print Err returned -2147417851
I have sw2009 sp4.1
Bdw. is crashing if I change weldment profile path in part doc, but assembly doc is working here without problems.
I Use it to create new parts via API. I open some custom parts eatch with his own drawing already made. I don't see how can I use in assembly this way. The idea is to automate the process of creating parts, it acess a data base to get a newcode and the weldment profiles to change "Base Parts" I already created, is like a shaft frequently used, so my base parts already have keyways and holes, in this process i used to change the profile, now i pause the macro to do it manualy then macro continues from this point, very furstating.. but thanks for the efford, maybe I can find an alternative knowing that in assemblies it work.
if you are creating new part you can also create temporary dummy assembly and put your part in there, for changing profile path and save your part and throw assy away.
humm. I'll gonna try that! I post back here if it worked.
there is also difference between model created in sw2008 and converted to 2009 and new created weldment in 2009. Another property sheet of structural member. Converted is missing groups and is crashing by weldmentprofilepath command.
uhuuuuuuuuuuuuuuuuuuuuuuuu \o/
Yes I am happy and yes there is a conversion problem..
All I have to do is make the base parts again but those are very easy to do...
Thank you a lot!!!!!
