Images in to worksheets
I have a picture in an Image in my UserForm.
I want to take this picture from the Image and insert it in a certain place on my active worksheet.
I have tried to use the following code but it does not work:
ws2.Pictures.Insert (Image4.Picture)
where ws2 is a my worksheet.
Does some one know how this can be done?
RE: Images in to worksheets
i dont know if it is what you are looking for but see attachment
Your attempt is reasonable. It is not working because, as deceptive as the macro recorder is, .Pictures is actually NOT a subclass contained within the worksheet object. Shapes, however, are.
If you set the picture to an object then you can mess with it after you add it, as follows:
CODE
Dim picMyPicture As Shape
Set wksMySheet = Worksheets("sheet1")
Set picMyPicture = wksMySheet.Shapes.AddPicture(Filename:="C:\Documents and Settings\All Users\Documents\My Pictures\Sample Pictures\Winter.jpg", linktofile:=msoTrue, savewithdocument:=msoTrue, Left:=100, Top:=100, Width:=200, Height:=200)
picMyPicture.Flip msoFlipHorizontal
Or if you just want to add it and not worry about it then you can use the following:
CODE
Call wksMySheet.Shapes.AddPicture(Filename:="C:\Documents and Settings\All Users\Documents\My Pictures\Sample Pictures\Winter.jpg", linktofile:=msoTrue, savewithdocument:=msoTrue, Left:=100, Top:=100, Width:=200, Height:=200)
I used the Call method so that I can specify which parameters are which. Makes it easier for myslef, and my coworkers to read it later.
-JTBorton
Well, You can try banging your head against the wall, but you just end up with lost-time injuries and damaged equipment. [M. Passman]
