Wire Pulley realistic Dynamic Modeling
Dear Experts,
Iam working on a project in which i have to study the dynamics of the Pulley wire mechanism.
The material of the wire is nonlinear.
I have the following questions:
1)Is it possible in Adams to model and run dynamic simulation of Pulley with nonlinear wire.
2)How to model a pulley in adams.
3)How to model a nonlinear wire without runtime error.
I will be thankful to you for your time and help.
Jamatics
Jamatics
RE: Wire Pulley realistic Dynamic Modeling
2)Obvious
3)Tricky - model it as a series of cylindrical or spherical parts joined by non linear springs. You then need to define contacts both between themselves and the pulley.
If you can't do 2 then don't even try 3
Computation time is likely to be enormous.
What runtime errors do you have? Chances are you have a lot of unconstrained degrees of freedom.
Incidentally building the cable is likely to be easier in a text editor than the GUI.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
