Are there alternatives to the Spline Tool for smooth curves?
The Spline Tool in CATIA is very cumbersome for me to create curves. In the past I used Maya to draw artist impressions of any design and it had a far easier system to control NURBS curves, as shown in this screenshot
http://w ww.cs.mtu. edu/~shene /COURSES/c s3621/LAB/ curve/orig inal-2.jpg
Is there a similar tool in CATIA that also defines NURBS curves using a polyline of weight points, rather than control points?
http://w
RE: Are there alternatives to the Spline Tool for smooth curves?
MTM
CSWA Certified
ATC Certified
CAD Blog
http://mtm-cadtutorials.blogspot.com/
Profile
http://www.linkedin.com/in/mtmcad
Thanks for pointing me to the smooth tool though, it's useful on itself.
I eventually found out that the curve tool from the Automotive Class A workbench works exactly the way I like, but it can't create closed curves and it's not really an issue.
Try the 3dCurve from the FreeStyle Module. It is very usefull. I use it very offen and it can be handled exactly like you showed in your picture. Instead of THROUGH POINTS select CONTROL POINTS from the CREATION TYPE combo box in the top of the appearing window. Take care about the working plan. The plan (XY, XZ, YZ) you want to draw on must be active (select MAKE PRIVILEG PLANE MOST VISIBLE from the right click menu of the compass) or you can simply pick points (not point objects, just pick) on a surface.
I hope this tool will help you.
