NX-Open Automatic Solid Density Change
New PostMeccanista (Aerospace)
30 Jun 09 9:48
I am trying to create a journal in NX-Open – Visual Basic to automatically change the Solid Density of a given set of part files.
It seems that the following simple piece of code has no effect while it is expected to set the density of each solid body in the workpart.
I am currently working with UG NX 4, .Net Framework 1.1, Windows 2000.
' NX 4.0.4.2
' Journal created by ...
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim length As Int32 = 0
Dim displayPart As Part = theSession.Parts.Display
theSession.ListingWindow.Open
        For Each obj As Body In theSession.Parts.Work.Bodies
            If TypeOf obj Is Body Then
                obj.Density = 1000
                length = length + 1
        theSession.ListingWindow.WriteLine(length & ": " & Ctype(obj.Density, String))
            End If
        Next
End Sub
End Module
RE: NX-Open Automatic Solid Density Change
There seems to be problem with setting the property.  The following works.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main
Dim ufs As UFSession = UFSession.GetUFSession()
ufs.Modl.SetBodyDensity(obj.Tag,UFModl.DensityUnits.GramsCentimeters, 1000.0)
length = length + 1
End If
Next
End Sub
End Module
Suresh
www.technisites.com.au
Very good, it works!
Thanks a lot.
