how to mount bearings for leadscrews
I'm designing a router for milling plastics and soft metals as part of my hobby. My fixed end leadscrews will be according the attached outline using 7200B bearings and 2 Belleville washers for preloading. Cutting forces transmitted to the bearings can be about 120N and I pretend to apply 240N of preloading to contact angle bearings. My hesitations begins when I try to imagine how to implement practical mounting of this system because I can not evaluate friction forces between spindle axis and inner bearings and I would like to ask to experts some questions
-What type of fitting when machining spindle axis would be the most adequate. I mean what is the practical tolerance between spindle axis and inner 7200B bearing
-What is the maximum practical temperature a can apply when preheating 7200B for mounting bearings to spindle axis?
-What is the maximum practical forces for mounting inner rings to an external axis for a typical fitting?
Thanks in advanced for any hint
RE: how to mount bearings for leadscrews
Russell Giuliano
http://ww
You'll find a lot of good info on mounting angular contact bearings there.
