FeatureManager Search and Component Display options
Currently I have an assembly. I am using the FeatureManager search with "Filter Graphics View" checked. However, what do I do if I want a subassembly to stay there no matter what I type?
So, any ideas on how to do this?
RE: FeatureManager Search and Component Display options
1) Temporarily add a dummy part, with the search parameter in its name, to the sub-assy.
2) Split the FM to show two trees. Use one panel to perform the search, and group select to highlight all selections. Then, from the other panel, select the sub-assy and activate the Isolate tool.
